problem to defined the geometry in autogrid 5 |
May 22, 2012, 11:04 |
ameer
i am student who new on autogrid 5 is working on naca blade 4412 series want to simulate mesh visualization. the problem is when i have done import from model catia the geometry of hub and shroud cannot be define. has anyone can help or show me how to define that geometry?
May 24, 2012, 03:50 |
wind turbine
razz
Rep Power: 15 |
current i had run in wind turbine simulation .... there anyone can give how to solve this problem..."sorry zest line : control point problem" thank in millionwind turbine.jpg this picture for ref.......
May 27, 2012, 22:45 |
If you are having the latest version of fineturbo, could you refer to tutorial stated in AutoGrid5 (basics) > Tutorial 3? This will guide you how the geometry should be defined to be 'readable' by AG5 and how is the import process will be. I hope this may help.
Regards CJ NUMIT Enterprise, Malaysia +6 017 656 3436 http://maccom-numit.blogspot.com http://www.numit.com.my Email : seiko.q@numit.com.my |
May 27, 2012, 22:46 |
Hi qiba,
Could i see your meridional view how is the geometry represented?
June 5, 2012, 23:33 |
hi cj
razz
Rep Power: 15 |
sorry for late reply.. this my Untitled.jpg..i hope you could help me..thank in million..
June 10, 2012, 02:51 |
Anyway you could refer to tutorial 3 as mentioned above? Then of you encounter any problem, please drop me an email.
June 13, 2012, 08:52 |
hi...
razz
Rep Power: 15 |
i ready settle that problem... this because of design of my hub.. ..
razz
Rep Power: 15 |
this my email.. tyuuu_2@yahoo.com
June 14, 2012, 13:09 |
(AutoGRID 5) Problem in Geometry definition of propeller
#9 |
venkatesh
Rep Power: 14 |
I am trying to generate a structured mesh for contra-rotating Propeller using Autogrid 5. The Propeller geometry is in IGES formate.I have a problem in the geometry definition of propeller. In the case of a propeller, the shroud does not exist. In the user Manuel It has been said that shroud must be defined using a curve cutting the tip of the propeller definition. But I am not clear with the definition. I tried to define my geometry without shroud definition but it in the geometry check it gives me a warning saying that shroud has not been defined. Can some one help me to mesh my geometry. Thanks in advance for your valuable information Venkatesh |
June 16, 2012, 11:00 |
hai ... venkat_aero2007
#10 |
razz
Rep Power: 15 |
i think you can search this tutorial for reference manual_user_autogrid_v51_2
Problem regarding hexagonal mesh of complex geometry. | saurabhk | Main CFD Forum | 1 | September 18, 2014 11:02 |
[ICEM] Problem in geometry creation by script | lavoz | ANSYS Meshing & Geometry | 4 | March 12, 2010 11:56 |
Cooling simple 3D geometry problem | Luk | FLUENT | 4 | May 12, 2006 10:47 |
Problem when I try to write the geometry file | massimo | Siemens | 0 | January 14, 2003 05:58 |
Geometry setup for phase change problem | Fred G. Kang | Main CFD Forum | 1 | October 14, 1998 12:41 |
