May 2, 2012, 18:38 |
air under hull
laurentL
Rep Power: 15 |
i am a new NUMECA user. in a simulation of a high speed boat, it look like air going under the hull. what is the influences parameters to limite this effect. thank you by advance for answers LL |
May 2, 2012, 19:38 |
laurentL
Rep Power: 15 |
sorry for disturbing,
the answer is in the documentation... increase orthogonality, longer acceleration, CiStreakCorrection_YES; uwCiCorrection_YES better question will be for a next time!!! |
February 4, 2013, 23:07 |
laurentL
Rep Power: 15 |
my actual problem is that coeficents, make the solution unstable... and so the results non available...
is there another solutions??? thank you for answering LL |
February 13, 2013, 21:42 |
KHB
Rep Power: 16 |
Hi, been trying NUMECA for a while for high speed boat simulation also.
As you said I did notice that the uwCiCorrection_YES makes the solution more unstable for me. The CiStreakCorrection_Yes is better though.. Btw, are you running the full unsteady or the quasi-static analysis? What is your Fn (by wetted length) that you are simulating? What is the y+ of your hull? If it is too small, try to increase it, I suspect the air entrapment is due to AR of the cells near the interface is too big and/or the mesh is not refined enough.. Increasing orthogonality / refining the mesh helps but CPU cost will increase a lot! Anyone has a suggestion? |
February 18, 2013, 10:27 |
laurentL
Rep Power: 15 |
i found a solution, you must adjust the uwCorretionCoef_ in the line just under uwCiCorrection_YES! for my case 0.3 was not enough but with 0.8 i had some good results. look at the pressure repartition on hull with this coef, it much better! |
Simulation of air flow in a chamber | Issa | CFX | 3 | November 23, 2009 18:16 |
Chemical Equilibrium Composition of Air and other Species | enigma | Main CFD Forum | 0 | November 11, 2009 20:08 |
Lumped air mass | Koranten | FLUENT | 0 | August 26, 2009 04:09 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 08:04 |
