target cell size for the internal free surface |
April 23, 2012, 20:30 |
laurentL
Rep Power: 15 |
dear all,
i am trying to mesh a boat 20m long, in a 100*40*30 meters box, with Hexpress. what can be the maximum target cell size to get a simulation of waves and boat drag not to bad... with X=1 y=1 z=0.01 and a aspect ratio of 100 i get 4 000 000 cells thank you for reply LL |
April 24, 2012, 19:37 |
Romain
Rep Power: 17 |
The usual guideline is to have a normal resolution of Lpp/500 or Lpp/1000, and to reach that kind of resolution with a level of refinement of 7 or 8. So basically your initial mesh size in the Z direction would be (Lpp/500)*2^7.
When it comes to waves, 80 points per wave length, and 10 points per wave height. |
August 6, 2014, 06:48 |
Lim Pei San
Rep Power: 12 |
I actually dont know how to find the target cell number since inside tutorial got teach but i already try use the formula that available in manual. However still cant get it. Is it i wrongly use the formula? Then i use the formula you write out, the value given out is so small. My Lpp is 1.372m |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
How to define size of domain for free surface simulation? | Sunya | Main CFD Forum | 2 | June 9, 2009 00:33 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
