I have written a finite difference code to simulate electromeagnetic field distribution. The scheme I have used involves fairly complex staggering of the solved variables - I have a number of variables at the cell centre, 3 variables on verticies and 3 variables on faces. We have got an ensight license so I am trying to write output filters for my results - the cell centred variables are no problem but I dont see how to do the vertex and face based variables. Are there any Ensight users who could advise me what to do Tim |
You may look at your User Manuel, chapter 11. You can reach it with the help menu button on your Ensight interface. Variable can be declare as "per node" or "per_element".
Hope that Help, Sylvain |
Rep Power: 16 ![]() |
I hope I do not forget wrong but as I remember while to generating your result based on node location you have to define all direction for variables.
For example six direction should be defined for node based for EnSight case format Velocity TX TY TZ RX RY RZ |
CGNS vs Tecplot Data Format | LWhitson2 | Main CFD Forum | 3 | July 1, 2011 14:50 |
Best format for simulation data? | cbisw | Main CFD Forum | 9 | May 30, 2011 03:38 |
OpenFOAM native format data visualization and workflow | zeliboba | OpenFOAM Post-Processing | 0 | September 12, 2008 09:44 |
XYZ (ASCII format) data points into GAMBIT | Neil | FLUENT | 1 | August 7, 2007 10:24 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
