Home > Forums > Visualization & Post-Processing Software > EnSight
need help ( generate binary file for Ensight )
Old   July 29, 2009, 00:54
Default need help ( generate binary file for Ensight )
Edward
jackson is on a distinguished road
my fortran code generte a binary file in Ensight Gold format,but reading error. i used the ens_checker.bat but it just a sudden flash and disappear,i saw nothing about the debug information. who can help me, thank you very much!
my fortran code is given below
subroutine ensgeobin
use typedef
use vars
use paras
implicit none
integer,pointer :: nl,fl
integer i,j,m,k
character(80) :: buf
integer,external :: nvface
open(99,file='ensight.geo',form='binary')
buf='Fortran Binary'
write(99) buf
buf='Geometry File in Ensight Gold Format'
write(99) buf
buf=''
write(99) buf
buf='node id given'
write(99) buf
buf='element id given'
write(99) buf
do m=1,nbsets
buf='part'
write(99) buf
write(99) m
buf=bcn(m)
write(99) buf
buf='coordinates'
write(99) buf
write(99) nbv(m)
write(99) (i,i=1,nbv(m))
write(99) (cc(1,i,m),i=1,nbv(m))
write(99) (cc(2,i,m),i=1,nbv(m))
write(99) (cc(3,i,m),i=1,nbv(m))
if(icnt_4(m)>0)then
buf='quad4'
write(99) buf
write(99) icnt_4(m)
write(99) (i,i=1,icnt_4(m))
write(99) ((to4(j,i,m),j=1,4),i=1,icnt_4(m))
endif
if(icnt_3(m)>0)then
buf='tria3'
write(99) buf
write(99) icnt_3(m)
write(99) (i,i=1,icnt_3(m))
write(99) ((to3(j,i,m),j=1,3),i=1,icnt_3(m))
endif
end do
close(99)
jackson is offline   Reply With Quote
Old   July 29, 2009, 10:11
kevincolburn's Avatar
Kevin Colburn
kevincolburn is on a distinguished road
Jackson,
It looks like you are running on a windows platform. If you are, then try to run the ens_checker from a command prompt window, rather than just executing the .bat file.
Open up a command prompt, change directory to the location of the case file, and then type in ens_checker90 or ens_checker82 (depending upon which you have installed). The command prompt window will not close, and you should see the debug information.
(If you are on a linux system, you could type : ens_checker90 mycase.case >& log.txt and you will get the whole output sent to the log.txt file which could then examine in detail).
-Kevin
kevincolburn is offline   Reply With Quote
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 15:30
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
