Home > Forums > Visualization & Post-Processing Software > EnSight
Plane Creation in Ensight
Old   October 27, 2023, 16:49
Default Plane Creation in Ensight
Talha Ahmad
talha_ahmed23 is on a distinguished road
I'm relatively new to Ensight, and I'm currently doing post-processing with it. I'm stuck on a problem - I want to limit the plane to the central section while excluding the outer portion. Could someone kindly point me in the right direction by suggesting which tool or steps to use for achieving this specific task? (Picture Attached!)
talha_ahmed23 is offline   Reply With Quote
Old   October 31, 2023, 05:59
Tobias
MFGT is on a distinguished road
So you want to have a clip plane, but not defined by Tool "xyz".
Therefore you selecet the Tool "plane" with clip extent "Finite".
You can right-click on the shown plane to edit properties.
MFGT is offline   Reply With Quote
ensight vizualisation
Gmsh Structured mesh that crached in openFoam simulation basma OpenFOAM 0 August 2, 2022 15:39
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 10:17
Creation of a plane surface with the TUI EmiS FLUENT 2 August 31, 2016 09:11
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
