Home > Forums > Visualization & Post-Processing Software > EnSight
Easiest Import Format? (Python)
Old   January 10, 2021, 12:09
Default Easiest Import Format? (Python)
Calceto is on a distinguished road
I have DNS data (from an in-house code) that I would like to import into Ansys EnSight for visualization, and to check some properties.
In the past, I have imported results from in-house codes into Hyperview by writing a Python script delivering the same format as a traditional simulation file. However, I no longer have access to Hyperview, and the formats I used are not compatible with EnSight.
Which format accepted by EnSight would be the easiest to follow in a Python script?
Thanks in advance,
Calceto is offline   Reply With Quote
Old   February 4, 2021, 15:28
Joern Beilke
JBeilke is on a distinguished road
"EnSight gold" format works perfect and is not too complicated.
JBeilke is offline   Reply With Quote
Old   February 4, 2021, 15:59
Hi JBeilke, thank you for your feedback, I will try using the format you mentioned.
I had been using Paraview lately
Old   February 4, 2021, 17:01
Joern Beilke
Ensight Gold works also very well with Paraview. There is also a binary form, which loads much faster.
There is also a tool called "ens_checker", which tells you if there are problems with your format.
Why can't I import data in csv format? liaoyun0126 FLOW-3D 1 June 4, 2022 17:03
[ICEM] import model always pending pulplus ANSYS Meshing & Geometry 1 July 1, 2020 04:49
[Discretizer] Installing Discretizer umassche OpenFOAM Community Contributions 26 January 25, 2017 06:33
How to import a data file (excel,txt or csv)to Fluent or CFD-Post (the easiest one)? silvai FLUENT 0 January 5, 2015 10:22
[swak4Foam] Calculate statistics for a cellSet with swak4Foam cnsidero OpenFOAM Community Contributions 12 September 10, 2013 19:52
