Home > Forums > Visualization & Post-Processing Software > EnSight
Creating a new Dataset on a part
Old   April 10, 2018, 19:27
Default Creating a new Dataset on a part
Wolfgang Black
wjbvg5 is on a distinguished road
I have an interesting problem. I have a massive simulation, which I typically trim down by creating an isovolume which is slaved to some variable (and can move through time). This reduces my simulation domain by lets say several orders of magnitude in terms of cells. What i'd like to do now is create a new dataset that is slaved to that isovolume so I can find various parameters without having to carry around regions which are not interesting.
For example, I want to create an isovolume which is 5 cm by 2 cm and grows to 5 cm by 3 cm through time. I want to find the average fluctuating mass fraction in y and then integrate this across x. I have been making a number of smaller iso-volumes across x to do so, but to do this I would need over 10k isovolumes (which my computational resources can not handle). Hence, I want to make the isovolume, then a database which relates the geometry to the mass fraction through time. I'd then save the database as a text file and do the correct calculations using those files. I'm sure there is a way to do this in ensight, and any help would be greatly appreciated.
Thanks so much
wjbvg5 is offline   Reply With Quote
Old   April 11, 2018, 12:23
Wolfgang Black
So I was browsing the forum and saw something on how to export geometric identities. I think this is very similar to what I want to do, but instead of using clips I want to use an isovolume. Is there a "correct" method to do so?
Again, the information I want is a scalar value associated with the mesh for a small 2D area of my simulation.
Any help would be greatly appreciated.
database, ensight, isovolumes, parts, post-processing
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Questions about creating interfaces for Multiple Regions famerfamer STAR-CCM+ 7 December 20, 2019 13:50
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. aarvay ANSYS Meshing & Geometry 2 May 11, 2012 12:15
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 04:02
