Home > Forums > Visualization & Post-Processing Software > EnSight
Enight after simulation re-start
Old   March 27, 2018, 15:50
Default Enight after simulation re-start
Ignacio
ignacio is on a distinguished road
I am saving the temperature fields of my transient simulation in the Ensight Case Gold format (Fluent 17.0).
If I stop and then re-start my simulation, the Ensight files saved after the re-start cannot be opened (I am using paraview). This is because after the re-start, the .encas file appends all the time steps (from time zero), whereas the .geo and .scl files only contain the time steps computed after the re-start.
The data is in the .geo and .scl files, but I cannot open due to this issue with the added time-steps in the .encas file.
Example of .encas file of the simulation until it was stopped
FORMAT
type: ensight gold
GEOMETRY
model: 1 1 Turbulence.geo
VARIABLE
scalar per node: 1 1 turb_kinetic_energy Turbulence.scl1
scalar per node: 1 1 production_of_k Turbulence.scl2
scalar per node: 1 1 viscosity_turb Turbulence.scl3
scalar per node: 1 1 viscosity_ratio Turbulence.scl4
scalar per node: 1 1 y_plus Turbulence.scl5
vector per node: 1 1 velocity Turbulence.vel
TIME
time set: 1 Model
number of steps: 124
time values: 1.00000e+01 2.00000e+01 (...) 5.65005e+03
FILE
file set: 1
number of steps:124
Example of .encas file of the re-started simulation
FORMAT
type: ensight gold
GEOMETRY
VARIABLE
TIME
time set: 1 Model
number of steps: 130
time values: 1.00000e+01 2.00000e+01 (...) 5.65005e+03 (...) 7.65005e+03
FILE
file set: 1
number of steps:130
I tried to simply delete the unwanted time steps from the .encas file (those prior to the re-start) and change the "number of steps" flag. However paraview still can't locate the time steps in the .geo and .stl files.
Can somebody tell me how to modify the .encas file to access the data?
Thanks a lot!
Ignacio
ignacio is offline   Reply With Quote
Start new Ansys Fluent automatically Malue Fluent UDF and Scheme Programming 0 September 28, 2017 11:53
Discrete event simulation vs. fixed time (discrete time simulation) jenjon FLUENT 0 March 10, 2013 07:58
Simulation and Optimisation of centrifugal fan 3D to 2D eRzBeNgEl STAR-CCM+ 0 January 31, 2013 14:21
Using 'define init' macro to perform a calculation at the start of a simulation jonnythewlis FLUENT 0 May 21, 2010 08:23
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
