Home > Forums > Visualization & Post-Processing Software > EnSight
how to combine two case files?
Old   March 6, 2018, 09:10
Default how to combine two case files?
Hiren Tala
hiren tala is on a distinguished road
In my post processing model
i converted from Converge to Ensight Formate of Post data in 2 parts(1 to 908 and 908 to 1450). so i have now two different files of .case If i call this folder in Ensight it opens either of the data not whole model ,but i want to make animation of whole model.
do i need to convert from converge again?
it takes more than 6 hours just to transfer the data.
what shoud i do?
your help will be highly appriciated.
thanks. !
hiren tala is offline   Reply With Quote
Old   March 8, 2018, 16:31
Joern Beilke
JBeilke is on a distinguished road
The case files are just text files which tell EnSight how your data are organised.
So you can open them with a text editor and modify them to load the timesteps you want.
JBeilke is offline   Reply With Quote
Old   March 8, 2018, 22:55
kevincolburn's Avatar
Kevin Colburn
kevincolburn is on a distinguished road
Further to Joern, your basename needs to be the same between the two runs, to allow the variables to be referenced in a single specification.
Edit the number of timesteps, and place the additional timesteps values into the .case file. The structure of the file should be fairly self-explanatory.
Kevin Colburn
Computational Engineering International, Inc.
www.ceisoftware.com
kevin@ensight.com
kevincolburn is offline   Reply With Quote
Old   March 15, 2018, 07:00
Hiren Tala
thank you all for the answers. i did and it worked.
Old   March 27, 2018, 15:39
Ignacio
ignacio is on a distinguished road
Hello all,
I am saving the temperature fields of my transient simulation in the Ensight Case Gold format (Fluent 17.0).
If I stop and then re-start my simulation, the Ensight files saved after the re-start cannot be opened (I am using paraview). This is because after the re-start, the .encas file appends all the time steps (from time zero), whereas the .geo and .scl files only contain the time steps computed after the re-start.
The data is in the .geo and .scl files, but I cannot open due to this issue with the added time-steps in the .encas file.
Example of .encas file of the simulation until it was stopped
FORMAT
type: ensight gold
GEOMETRY
model: 1 1 Turbulence.geo
VARIABLE
scalar per node: 1 1 turb_kinetic_energy Turbulence.scl1
scalar per node: 1 1 production_of_k Turbulence.scl2
scalar per node: 1 1 viscosity_turb Turbulence.scl3
scalar per node: 1 1 viscosity_ratio Turbulence.scl4
scalar per node: 1 1 y_plus Turbulence.scl5
vector per node: 1 1 velocity Turbulence.vel
TIME
time set: 1 Model
number of steps: 124
time values: 1.00000e+01 2.00000e+01 (...) 5.65005e+03
FILE
file set: 1
number of steps:124
Example of .encas file of the re-started simulation
FORMAT
type: ensight gold
GEOMETRY
VARIABLE
TIME
time set: 1 Model
number of steps: 130
time values: 1.00000e+01 2.00000e+01 (...) 5.65005e+03 (...) 7.65005e+03
FILE
file set: 1
number of steps:130
I tried to simply delete the unwanted time steps from the .encas file (those prior to the re-start) and change the "number of steps" flag. However paraview still can't locate the time steps in the .geo and .stl files.
Can somebody tell me how to modify the .encas file to access the data?
Thanks a lot!
Ignacio
ignacio is offline   Reply With Quote
Old   April 10, 2018, 08:32
Hiren Tala
i have one another Problem
i combined the .case file but when i am trying to open , error comes like
"Unable to read data
see server console output for more information"
How to save ANSYS 16.2 fluent case and data files to open in version15.0 krishna.n FLUENT 0 July 29, 2016 02:23
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
Different case files activate ALE Eq. kevin FLUENT 0 November 2, 2006 14:39
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
