Home > Forums > Visualization & Post-Processing Software > EnSight
about graphics issue
Old   October 8, 2017, 14:15
Default about graphics issue
Hiren Tala
hiren tala is on a distinguished road
Hello
i want to drag CH4 in cutting mid plane of cylinder and want to see its flow, but problems of graphics arise, can anyone tell me the solution for that. thanks in advance.
hiren tala is offline   Reply With Quote
Old   October 13, 2017, 16:30
Marina G's Avatar
Marina Galvagni
Marina G is on a distinguished road
The problem is that your machine doesn't have a graphics card that supports the drag&drop operations. Therefore, these operations are not available.
As a solution, you can update to the newer version of EnSight - 10.2. This version contains some changes that will allow you to perform these operations even with a low end graphics card.
Please note that, while very handy, these kind of operations are not necessary. You can reach the same result with other approaches. For example, right-click on the part(s) in the part list -> Color by -> Select variable, instead of drag&drop the variable onto the viewport.
Best Regards,
Marina Galvagni
CEI Software Support Engineer
Marina G is offline   Reply With Quote
Convergence issue in natural convection problem chrisf90 FLUENT 5 March 5, 2016 09:30
Strange issue while launching ANSYS workbench in CentOS 6.4 Philip_C ANSYS 11 August 29, 2013 07:44
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 03:00
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 09:27
How to change and fix the size of graphics window? Rob FLUENT 1 February 7, 2003 11:15
