Home > Forums > Visualization & Post-Processing Software > EnSight
Block traces using arbitrary surfaces
Old   February 21, 2017, 16:53
Default Block traces using arbitrary surfaces
Abraham
ameganat is on a distinguished road
Is it possible to block particle traces using arbitrary surfaces? (say traces entering a certain arbitrarily shaped region should vanish)
ameganat is offline   Reply With Quote
Old   February 21, 2017, 21:18
kevincolburn's Avatar
Kevin Colburn
kevincolburn is on a distinguished road
You can use the Tools capability within EnSight to create "Inside" or "Outside" clips. In its basic form, you can use the plane tool, and "clip" the particles which are either on the positive, or negative side of the plane.
You can use the other tools like Box, Cylinder, Cone, Sphere, or Revolution Tool to "clip" the particles on either side of those tools. The Revolution tool can be helpful in being able to restrict particles. Depending upon you exact surface requirement, I've found the Revolution Tool can be typically used to restrict the particles sufficiently.
More help is available through our main support channel support at ensight dot com.
-Kevin
Kevin Colburn
Computational Engineering International, Inc.
www.ceisoftware.com
kevin@ensight.com
kevincolburn is offline   Reply With Quote
ensight, traces
Creating arbitrary surfaces in meshed domain suh OpenFOAM 7 August 20, 2019 14:27
[ICEM] Split Block results in not wanted premesh surfaces pizzaspinate ANSYS Meshing & Geometry 0 January 7, 2016 09:12
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 17:37
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 11:01
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
