EnSight - queue of command files and abaqus post-processing |
June 1, 2016, 06:26 |
Paul
Rep Power: 14 |
I have prepared a command file (.enc) which performs some post-treatment operations on my results. I need to perform it many times on different result files (actually many scripts with different paths / results etc.). I would like to run it all in a sequence through the batch mode, I found that I can run one with the following command: Code:
ensight100 -batch 1920 1200 -p Depouillement_NS3D_Venturi_BAS_REF_C3a.enc Code:
ensight100 -batch 1920 1200 -p Depouillement_NS3D_Venturi_BAS_REF_C3a.enc ensight100 -batch 1920 1200 -p Depouillement_NS3D_Venturi_BAS_REF_C3b.enc ensight100 -batch 1920 1200 -p Depouillement_NS3D_Venturi_BAS_REF_C3c.enc Is there any command which forces EnSight to wait until the first script is finished and run the next one and so on? My second question is not related to the first. How can I open abaqus .odb file in EnSight? In my version there is not such option. Is there additional package which permits to do this? Thank you in advance! Best Regards, Delcraft |
June 1, 2016, 17:38 |
Marina Galvagni
Rep Power: 12 |
Hi Paul,
That seems to be a problem with the bat script. You need to add a "call" at the beginning of each command, so that your script becomes: call ensight100 -batch 1920 1200 -p Depouillement_NS3D_Venturi_BAS_REF_C3a.enc call ensight100 -batch 1920 1200 -p Depouillement_NS3D_Venturi_BAS_REF_C3b.enc call ensight100 -batch 1920 1200 -p Depouillement_NS3D_Venturi_BAS_REF_C3c.enc Give a look here and links in this page for a more detailed explanation of why you need the "call": http://stackoverflow.com/questions/4...t-all-three-li About your second question: the Abaqus reader is not installed by default with EnSight. When you run the installer, you will need to explicitly select it to have it added to your installation. It sounds like this reader wasn't selected when you first installed EnSight. To add it, simply re-run the installer and select the Abaqus reader. This will add the reader in your installation. If, after this, you still don't see the Abaqus reader, it's possible that it is set to not be visible in your instance of Ensight. Open EnSight and go into Edit -> Preferences -> Data. A list of all available readers will appear. Select the Abaqus reader so that you have (*) next to it, and save the preferences. Now you should be able to see the reader every time you open EnSight. Let us know if you have more questions or problems. Bests, Marina Galvagni CEI Software Support Engineer |
batch mode, command file, ensight, queque |
