May 18, 2016, 21:13 |
Finding the coordinates of density
Wolfgang Black
Rep Power: 11 |
I'm trying to use a countour of density/species to outline my interface. I'd like to use this contour, which stretches and at one point inverts, to find for me the max and min coordinate values. I tried to use isolines of species for this but when the interface inverts they die. At the moments I can plot the contours, but can't do any operations on them. Any advice would be appreciated. Thanks so much, |
May 19, 2016, 21:06 |
Kevin Colburn
Rep Power: 17 |
You can try to use IsoSurfaces. If the parent part is a 2D part, then the created IsoSurface will be 1D, at a constant single value. You can then query the min (or max) coordinate of the IsoSurface. In principle, the IsoSurface is effectively a single Contour. The benefit is that the IsoSurface is a proper part, with coordinates.
Kevin Colburn Computational Engineering International, Inc. www.ceisoftware.com kevin@ensight.com |
[ICEM] Geometric density sources in ICEM | rana41671 | ANSYS Meshing & Geometry | 2 | June 14, 2018 06:44 |
How to model Salinity, density, fresh water & sea water | grayback87 | FLUENT | 3 | December 30, 2014 03:00 |
Finding Coordinates of Mesh Nodes | salijav | Main CFD Forum | 1 | October 24, 2012 01:57 |
Finding Maximum Coordinates of a Surface | ChristianF | CFX | 1 | August 18, 2011 11:45 |
density update by UDF in non-premixed combustion | IKSOO | FLUENT | 2 | December 8, 2002 21:37 |
