Home > Forums > Visualization & Post-Processing Software > EnSight
Particle diameter distribution
Old   March 3, 2016, 01:37
Default Particle diameter distribution
Unnikrishnan T P
unnikrishnan is on a distinguished road
Hi, I have particle data and cell data exported to EnSight. I want to get particle diameter distribution at a clip plane. How to do this?
unnikrishnan is offline   Reply With Quote
Old   March 7, 2016, 15:45
Marina G's Avatar
Marina Galvagni
Marina G is on a distinguished road
If your particles have node IDs, then it is possible to create a particle trace for each node, and to export the information about the path of each particle trace through the streamline analyzer python script. Once you have exported the information, you will be able to do your analysis for the distribution of particle diameter on a clip plane outside of Ensight.
Please send an email to support@ensight.com if you are interested in getting the streamline analyzer script.
Best Regards,
Marina Galvagni
CEI Software Support Engineer
Marina G is offline   Reply With Quote
ensight, particle distribution
Diameter distribution, Search for options ?! souria FLUENT 0 January 22, 2016 09:38
injection problem Mark New FLUENT 0 August 4, 2013 02:30
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Particle Size Distribution with R-R fails? HP FLUENT 6 May 19, 2005 07:35
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 04:56
