Home > Forums > Visualization & Post-Processing Software > EnSight
Export video format
Old   March 1, 2016, 23:50
Default Export video format
jhuang's Avatar
Jing Huang
jhuang is on a distinguished road
I remember I could export animation into .ogv file before. Recently we upgraded to 10.1.1(b) and I could not find that option any more. Is it not supported in newer version?
Thanks!
Jing Huang
Research Engineer
CONVERGECFD
jhuang is offline   Reply With Quote
Old   March 2, 2016, 14:41
Marina G's Avatar
Marina Galvagni
Marina G is on a distinguished road
Hi Jing,
EnSight doesn't have an exporter for the ogv format. If you had it in a previous version, it may mean that someone created a library for it and placed it in the Ensight's installation - but it doesn't come from CEI.
If this is the case, you should be able to make a copy of this ogv library and place it also in the installation of the new version of EnSight, so that you can use it also with 10.1.x.
The libraries for exporting images and animations in EnSight 10.0.x are in $CEI_HOME/apex30/machines/linux_2.6_64/udil
Locate the library for the ogv format, copy and paste it in the equivalent location for EnSight 10.1.x:
$CEI_HOME/apex31/machines/linux_2.6_64/udil
As a side note: EnSight 10.1.1(b) is ~ 2 years old. As you're updating your version of EnSight, you might want to update to the latest version available, currently 10.1.6(b).
Hope this helps.
Best Regards,
Marina Galvagni
CEI Software Support Engineer
Marina G is offline   Reply With Quote
mesh export to gmsh format Kelomari enGrid 0 September 22, 2015 20:35
[General] A "clean" solution to export binary ensight gold format from Fortran to Paraview? flotus1 ParaView 1 June 23, 2015 12:59
Unable to install OpenFOAM 1.6-ext Maimouna OpenFOAM Installation 23 May 8, 2014 06:47
Export to Abaqus input format jai CFX 1 July 21, 2010 05:53
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
