Home > Forums > Visualization & Post-Processing Software > EnSight
Using a variable to scale a function
Old   November 17, 2015, 13:54
Default Using a variable to scale a function
Wolfgang Black
wjbvg5 is on a distinguished road
I'm trying to post-process some data in Ensight and I would like to get the circulation along an interface. I can define the interface by a variable I have, we'll call it species.
I'd like to write something like,
if(species.LT.0.99) then
if(species.GT.0.01) then
vort(u)
IntegralSurface(vort,[])
else
end
else
end
But I can't get if/then statements to run. I see the calc. has If_LT but this isn't working the way I thought it should. I'm unsure how to create this in ensight, any advice would be appreciated
wjbvg5 is offline   Reply With Quote
Old   November 17, 2015, 20:43
kevincolburn's Avatar
Kevin Colburn
kevincolburn is on a distinguished road
I'd approach this problem in the following manner:
1. Select the parent model part (typically the fluid domain).
2. Using the Element Filter capability (2/3 of the way along the top row of EnSight's icons with the Part selected).
3. Specify a filter rule of Species > 0.99 (remember that the Filtering is "filtering out").
4. Specify a second filter rule, with Species < 0.01; Use the "and" option I believe.
The result, should be that your Parent part (the fluid domain) is now only where species < 0.99 and > 0.01
5. Now, Clip this domain (if needed) to obtain your clip of interest (interface).
6. Compute vort(u) and IntegralSurface(vort,[]) on this clip.
The key here is to first filter the model parent parts based on the species variable. Then, take a clip of that parent... and operate from there.
Please feel free to contact CEI Support directly for any assistance, questions, or additional information.
-Kevin
Kevin Colburn
Computational Engineering International, Inc.
www.ceisoftware.com
kevin@ensight.com
kevincolburn is offline   Reply With Quote
calc, ensight, functions, user-defined
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Variable Density Function ryzd FLUENT 1 August 25, 2011 15:16
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 14:38
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
