Creating an isosurface with a FLOW-3D Hybrid Shallow Water Model |
July 26, 2015, 20:04 |
Rep Power: 13 |
Hi everybody,
I have problems to create a isosurface with shallow water model (FLOW-3D) . best regards |
July 27, 2015, 13:58 |
Marina Galvagni
Rep Power: 12 |
In general, to create an isosurface in EnSight, do the following. In the part list (top-left), select the model part that is the fluid part. Go into Create -> Isosurface. Set your variable from the variable list pull down. Set the value for the isosurface in the "Value" field. Then, hit "create". This will create a new part that is composed of 2D elements where the variable has value corresponding to the one you've set. If after following these instructions you still have problems, please let us know more details of what kind of problems you're facing. If you wish to send us the dataset to give it a look directly, so we can verify if there's some problem in the way EnSight loads / sees the data, you can contact us at support@ensight.com Thank you. Best Regards, Marina Galvagni CEI Software Support Engineer |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Air-lift model with hot gases and water. Time step problem. | PauliusRap | FLOW-3D | 0 | August 4, 2014 04:47 |
Cavitating Flow around a hydrofoil | kimotbwb | CFX | 0 | October 7, 2012 10:05 |
Hybrid Shallow Water/3D Flow Model | Hamed&honey | FLOW-3D | 5 | September 19, 2012 02:27 |
Coupled Flow model | RalphS | OpenFOAM | 1 | November 15, 2010 03:51 |
