Rep Power: 13 ![]() |
I have made a clipping plane, and I want to get the orthogonal view to it to be able to observe everything in true magnitude. Does anyone know how to do it?? Thank you!!! |
Kevin Colburn
Rep Power: 17 ![]() |
Currently, you have a few options. They are not ideal, and there is feature request to add a more direct/simple way to do this. Until then, here are couple of options:
a. If the Clip is made with the Plane Tool, then you can set the CAMERA normal to the Plane Tool. Viewports take their view into the scene from Camera, and thus the view can be normal to the plane. b. If you only want to show that part in a viewport, you can modify the viewport to be a 2D viewport. Only that 2D part will be shown, and the view will remain normal to that part. We hope to have an easier/direct method to do this in the near future. -Kevin
Kevin Colburn Computational Engineering International, Inc. www.ceisoftware.com kevin@ensight.com |
Thank you very much, Kevin!! I am not sure how the camera thing works, but I will take a look at it
#4 | |
Josef Dobeš
Rep Power: 14 ![]() |
could you give me more information step by step to the option a? I tried the option b and it works nicely, but I have a question: Am I able to rotate 2D view (create by option b) by 90 degree clockwise or counterclockwise? Thanks |
ensight gold, orthogonal view |
View with cut plane | Mudblood | FLUENT | 5 | April 4, 2020 10:17 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 17:24 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
