April 19, 2014, 06:10 |
ensight is not opening???
Manjunath Reddy
Rep Power: 13 |
Hiii ,
I'm new to ensight I installed ensight trail version while running ensight100 command to open it is showing this error Using CEI_HOME = /opt/CEI Using CEI_ARCH = linux_2.6_64 DISPLAY = :0 hostname = manjunath-SVE15136CNB <Starting OpenGL version (Use -X for software rendering)> /opt/CEI/apex30/machines/linux_2.6_64/cdfapp: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory please help me Regards Manjunath |
April 21, 2014, 09:18 |
Eric O'Connell
Rep Power: 12 |
Have you contacted support@ensight.com or the person who sent you the trial key of EnSight? I am sure they will be able to help you figure out why EnSight will not load.
April 21, 2014, 11:50 |
Eric O'Connell
Rep Power: 12 |
Manjunath,
See this FAQ about the issue you are having. https://support.ceisoftware.com/entr...d-Requirements Regards, |
April 21, 2014, 13:58 |
Eric O'Connell,
Manjunath Reddy
Rep Power: 13 |
Thank you very much for your help
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 19:00 |
[General] Problem opening Ensight File | Jeff74A | ParaView | 2 | July 22, 2013 04:42 |
opening sims as a wall. | Curran919 | CFX | 8 | March 19, 2012 22:31 |
opening ensight case in open source visualizer | clhona | Main CFD Forum | 13 | December 15, 2006 18:59 |
