Home > Forums > Visualization & Post-Processing Software > EnSight
Ensight grid creation
Old   March 14, 2014, 04:37
Default Ensight grid creation
KellyM is on a distinguished road
Hi, I am a new Ensight user, and I am attempting to create an image showing the time-averaged velocities (using vector arrows) of particles in my system (a rotating cylinder). I want to create a 100x100 grid centred on this cylinder, so that I am able to perform calculations in each section of the grid. Can anyone point me in the right direction as to how to split my rotating cylinder Part into the desired subsections?
Thanks
Kelly
KellyM is offline   Reply With Quote
Old   March 15, 2014, 13:55
Default Grid Clip
kevincolburn's Avatar
Kevin Colburn
kevincolburn is on a distinguished road
Kelly,
If you are looking to display the velocity vectors from your continuum on a a uniform grid, you can simply use the Clip Plane Creation, Along with the Plane Tool. With the Plane Tool, you can either use the resolution of the mesh, or specify a "Grid" clip, where you can specify the X and Y resolution in a uniform fashion. This will intersect the domain with a regular grid, on which you can display vector arrows (typically at each node of the grid).
If you have further questions, please do not hesitate to contact your local EnSight Support representative in your region, or via the main help line (support@ensight.com).
-Kevin
Kevin Colburn
Computational Engineering International, Inc.
www.ceisoftware.com
kevin@ensight.com
kevincolburn is offline   Reply With Quote
Old   March 18, 2014, 05:42
Hi Kevin, Thanks so much for your response. I am actually looking to make a 3d grid, with x, y and z components, where I can extract information from each grid element and get averages.. I will try contacting my Ensight rep as well. Cheers
O grid creation failed dhxlxz ANSYS Meshing & Geometry 2 December 10, 2009 22:05
[ICEM] Double Y grid and single Y grid brissyben ANSYS Meshing & Geometry 5 July 27, 2009 10:24
Grid refinement. Sas Main CFD Forum 8 September 2, 2005 09:36
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 09:32
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 23:26
