May 9, 2012, 03:19 |
#21 | |
Safia
Rep Power: 16 |
Regards |
October 7, 2015, 09:33 |
2D Simulation in CFX
#22 | |
Rep Power: 14 |
I've created a 2D mesh in ANSYS Mesh. Then I've tried to import it in CFX (wishing it would extude it 1 cell thick), but a message informs me that there has been an importing error, since "Only 3D volume meshes can be imported". I need to run a "2D" simulation in CFX. What can I do? Many thanks |
October 7, 2015, 11:17 |
#23 | |
Rep Power: 18 |
October 7, 2015, 11:54 |
#24 | |
Rep Power: 14 |
I had already set, in "Solver Preference" CFX. But, as I reported before, when I try to import the surface mesh to CFX, then I get the previous merror message. I really really neeed an help, thanks! |
October 8, 2015, 01:09 |
#25 |
Rep Power: 18 |
October 8, 2015, 05:34 |
#26 |
Rep Power: 14 |
October 8, 2015, 06:55 |
#27 | |
Rep Power: 18 |
1. Export mesh to say fluent file format. Then open CFX and import it (don't connect Mesh and CFX analysis systems). 2. Extrude your geometry in DM and then generate mesh. |
October 8, 2015, 07:05 |
#28 | |
Rep Power: 14 |
Now I have a new question: The thickness mesh (the contour of the 3D mesh, which is 1 cell wide) cannot be separated in portions. And I need to create different bundaries like inlet, outlet and so on... How can I "brake" the "wall surface body" (that's the name of the contour) in order to create the different bundaries? Thanks again! |
CFX thermo-fluid 2D simulation problems | maryliz | CFX | 6 | November 1, 2011 00:26 |
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong | jannnesss | CFX | 5 | February 25, 2011 17:24 |
Problems with importing ICEM-CFD mesh in CFX | signofra | CFX | 3 | March 3, 2010 11:08 |
Problems on running cfx in parallel | Nan | CFX | 1 | March 29, 2006 05:10 |
run Build Topology in IcemCFD 4 CFX | Ahmed | CFX | 3 | March 19, 2004 17:59 |
