March 30, 2012, 05:16 |
question need answer, pls
Safia
Rep Power: 15 |
Hi all
I'm using the idael gas material fro my simulation; and when I modify the air properties as function of temp., my results become the same if I used constant properties..(did not make sence)!!! So what you think the wrong come from??? I'm looking to hear from you soon. Please any input can help. |
March 30, 2012, 05:35 |
Rep Power: 15 |
May be the temperature variation in your simulation is not significant enough to cause any change in results. So even when you use temperature dependent properties, the results are similar.
Also, I am assuming here that the properties you are referring to here are viscosity, conductivity etc and not density. |
March 30, 2012, 05:45 |
Rep Power: 144 |
As Chander says, most people think "variable properties" is viscosity, conductivity, specific heat etc, and not density. Most people consider variable density as simply a compressible flow simulation.
And another point - in future can you use a thread name which describes the thread? |
March 30, 2012, 07:35 |
Luis Filipe Fabiani
Rep Power: 17 |
Have you set the "Heat Transfer" under "Fluid Models" to "Thermal Energy"??
If it is "Isothermal", all properties will remain constant. Best regards |
March 31, 2012, 00:01 |
#5 | |
Safia
Rep Power: 15 |
March 31, 2012, 00:05 |
Safia
Rep Power: 15 |
March 31, 2012, 00:08 |
Deltha T is large enough
#7 | |
Safia
Rep Power: 15 |
Thanks again |
Is there need to use BL in 2D pipe | Salam | FLUENT | 2 | September 30, 2007 15:45 |
To red lemon pls answer | K.Baker | FLUENT | 0 | August 2, 2007 09:41 |
Who can answer me /pressure question | pam | FLUENT | 7 | June 23, 2007 07:50 |
Convergence Question | James | FLUENT | 2 | October 29, 2005 14:59 |
A simple question (Where is the answer? Not yet!!) | Mecobio | Main CFD Forum | 1 | February 12, 2004 07:28 |
