Need help in calculating variables in cfx post
Old   March 28, 2012, 04:18
Default Need help in calculating variables in cfx post
Shashwat
shaswat is on a distinguished road
Dear friends
I have taken 5 degree slice of my axis symmetry model. the solution got converged.
How to see the full model as a benefit for the symmetry boundary conditions. I tried instance transform option, but I could n't.
Any help greatly appreciated
Thank you
Regards
Govind
shaswat is offline   Reply With Quote
Old   March 28, 2012, 04:38
Lance
Lance is on a distinguished road
Right click Default Domain,
# number of copies: 72 (360°/5° = 72°)
Apply rotation
specify which axis to rotate around
Lance is offline   Reply With Quote
Old   March 28, 2012, 05:38
Shashwat
Apply rotation
Thank you Mr Lance
I just ask you, Since my model is 5 degree slice , during meshing I set the element size very very small. If I transform to full model , My system hangs. .is it the above reason?
Next
my model is a venturi model. But I modelled as a 5 degree slice. The flow is Z direction . I want to measure the average pressure at a distance (say 5cm from the inlet). How can I measure it in the sliced model. Is that measurement is equal to the average pressure at distance of 5cm when it is transformed to the whole model?
Please clarify my doubt. If this is the case no need to transform to full model. am I right?
Thank you
Regards
Govind
Old   March 28, 2012, 05:53
Lance
Put a plane where you want to measure and calculate the average pressure. If your model is axisymmetric then the average pressure in a slice should be the same as for the whole model.
Dont know why your computer hangs.
Old   March 29, 2012, 04:36
Shashwat
Dear Mr Lance
I would like to know how to calculate wall shear stress between fluid and porous interface
Regards
Govind
New Variable in CFX Post Ben CFX 9 June 20, 2012 19:10
Adding results in CFX 11 post Dimitri CFX 0 February 5, 2008 05:28
CFX definitions of Rotating Variables: Confusing! Prakash CFX 0 November 8, 2005 02:24
CFX post to Tecplot nandu CFX 2 December 4, 2002 09:27
CFX POST mpeg Revisited henry CFX 2 November 22, 2002 12:42
