June 29, 2012, 09:57 |
#21 | |
June 29, 2012, 10:01 |
#22 | |
Mina
Rep Power: 15 |
So you mean bigger mesh near the wall gives better results? in my model y+ is varying between 0-40, so in the region by y+>11 the standard wall function is working well while in the region by y+<11 is giving us wrong results. on the other hand i read in ansys documentation that at least 10 nodes in boundary layer is needed, so we need bigger mesh for the wall function and smaller mesh for accuracy !!!!! |
July 1, 2012, 09:35 |
#23 |
Rep Power: 144 |
Yes, ideally you want all nodes to be y+>11 for standard wall functions. And you are correct in that often contradicts the requirement for sufficient nodes in the boundary layer.
The best solution is usually to use the SST turbulence model with automatic wall functions and it can handle just about any y+. If you still want to stick with standard wall functions then I would do a y+ sensitivity check. You may well find that your simulation is not very sensitive to y+ anyway, and in this case you can run any y+ you like (within reason). |
July 1, 2012, 09:43 |
#24 |
I would like to share my work on turbo machinery. In this case, i tried the Yplus 1, 10 and 60 with scalable wall function and Y+ = 10 with standard wall function. Results clearly show the problem with standard wall function.
July 1, 2012, 09:59 |
#25 |
In case of SST y+ greater than 10 does not produce the good results as shown in this pic: Definitely this is the difficult case for any turbulence model and wall treatment. In simpler cases, you might not find any difference at all
July 1, 2012, 19:22 |
#26 |
Rep Power: 144 |
Nice dataset Far. Shows the wall boundary condition is important in your turbomachinery case.
But do not make the mistake in assuming therefore it is important in all cases. CFD covers a very wide range of applications, and in quite a few of them the wall boundary condition details does not make much difference. For instance HVAC modelling. |
July 2, 2012, 05:50 |
#27 | |
Mina
Rep Power: 15 |
Thanks for nice explanation, one basic question, in the model you usualy have a range of Y+ , when you say y+=1, 10, ... you are talking about the maximum y+ in the model, am i right? |
July 2, 2012, 06:08 |
#28 | |
But I want to point-out one important aspect. If you are not solving the equations with integration to the wall approach then you may not be able to predict the quantities accurately e.g. drag on airfoil. So when you are using the wall function you may miss the important flow physics. Obvious fact On the other side as you have pointed out that if you solve the HVAC problem with intergration to wall approach or wall function apporach, it wont make any difference at all. Very true and I agree again. But if you are putting the wrong numerics i.e. using the integration to wall mesh for the standard wall function you are forcing the numerical algorithm for the things it was not designed. So we should keep the wrong numrics and wrong physcis into separate boxes. |
July 2, 2012, 06:15 |
#29 | |
I am talking about the average values on the blade surface. I have some how higher values at the leading edge and lower values at separation point( Y + = 1-20 for Y+ = 10 case). But that portion is not more than 5-10%. For example for Y+1 mesh, Maximum Y+ is 5-6. I shall try to post the pic of Y+ values (Y+ and solver Y+) |
July 2, 2012, 06:20 |
#30 |
see Fig. 9 in this reference http://num.math.uni-goettingen.de/ba...ings/knopp.pdf for the definition of average Y+
This is also another reference by same author. http://num.math.uni-goettingen.de/ba...ngs/alrutz.pdf See Fig 4 Note the difference for the SA and SST model for the range of Y+ values. Knopp recommends the Y+ <=10 for SA model for good results for flow with stagnation, separation etc. And higher values for SST model. |
July 2, 2012, 07:16 |
#31 |
See Fig 1 & 2 http://www.mscsoftware.com/events/ae...pdf/p10201.pdf
Slide 20 http://www.powershow.com/view/b0e25-...n#.T_FzQxdKol8 Slide 21 http://www.docstoc.com/docs/10845119...mics-Using-CFX General comments about turbulence model and wall treatment with good data from industry. http://www.ansys.com/staticassets/AN...pabilities.pdf Slide 34 clearly states that the Y+ insensitive treatment is availalbe for all turbulence models in ANSYS CFD (CFX+Fluent+other modules) https://www.sharcnet.ca/Software/Flu...bModeMath.html http://www.mathematik.uni-dortmund.de/~kuzmin/IJCSM.pdf http://nippon.zaidan.info/seikabutsu...okyo_ts059.pdf http://www.idac.co.uk/products/downl...NSYS%20CFX.pdf |
July 2, 2012, 07:59 |
#32 | |
Mina
Rep Power: 15 |
Many Thanks Far ! |
July 6, 2012, 14:53 |
#33 |
pooyan
Rep Power: 15 |
Hi All,
I was reading your discussion for standard and scalable wall functions. I have a question which may not be related to your discussion, but maybe I can get the answer from you. I do not know where the boundary conditions for U at first grid point is defined in OpenFoam when using wall functions. I expect to see some values for U at the first grid point based on log law equation, but I can not find this implementation through the code. can you please help me on that?! ( I see some implementation for k, epsilon and nut in their corresponding wall functions but nothing for U) So, for the first grid point, do we still solve equations to obtain U?! I will be so appreciated if you can help me with this question. thanks |
July 8, 2012, 08:19 |
#34 |
Rep Power: 144 |
This is the CFX forum, try the Openfoam forum for that question.
March 7, 2015, 11:22 |
#35 | |
Rep Power: 12 |
It's not very clear for me, I wonder if below Y+ = 11.06 mesh points are ignored or below Y+ = 11.06 mesh points are set up to y+ =11.06.
But if it's the last option, this means that we associate a y+ of 11.06 on cell initially too small, do you see what I mean ? Quote:
Wall function for velocity? | johnblund | OpenFOAM | 3 | September 6, 2022 08:22 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Need some wall function approaches! | yka8150 | Main CFD Forum | 0 | September 22, 2009 00:08 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
