How to assign the inlet B.C using a bunch of data set for an unsteady problem? |
March 13, 2012, 23:51 |
Ali
Rep Power: 15 |
Hello Guys,
I'm going to assign a bunch of data set as an inlet boundary condition. The problem is, the inlet B.C changes with time. For example at t=t1, I have to read the first data set and for the next timestep I have to read the next data set. Note that the problem is unsteady and I have to assign the velocity (u and V components) to the inlet boundary condition at different time step. For a steady problem, I know how to do that. I just need to use the "initialize profile data", but for an unsteady problem, I do not know how I should tackle the problem. I would appreciate your help in advance. Thanks, Ali |
March 14, 2012, 03:49 |
Lance
Rep Power: 22 |
Search the forum, it has been asked many times before. Or, have a look here:
http://www.edr.no/blogg/ansys_blogge...nsient_profile |
March 21, 2012, 14:55 |
Ali
Rep Power: 15 |
Thanks, Lance for your reply. So, it means that I do not need to write a code to assign the boundary condition.
March 28, 2012, 19:41 |
Hesam Moghaddam
Rep Power: 14 |
Dear Ali and Lance,
I input an excel data file using the link you gave. It is the curve for a pulsatile blood flow. I applied these data as my inlet B.C. Actually CFX doesn't show any plot or anything to make us sure that it is using the same curve? do you know a way to verify the shape of curve from the data I input in CFX? like when you enter an equation in expression part it gives a plot according to the formula you entered and you can see if it is taking the data in a good way or not? Thank you, Regards |
steady RANS for flow problem with unsteady inlet? | kat | Main CFD Forum | 0 | February 16, 2009 11:24 |
Fan Modelling Problem in CFX | Jenny | CFX | 8 | September 11, 2007 14:59 |
which B.C. i should apply for this problem? | raivish | CFX | 0 | January 6, 2006 09:47 |
Need help: strange problem of unsteady B.C. UDF | Z. T. | FLUENT | 0 | April 11, 2003 20:03 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
