March 12, 2012, 20:06 |
Opening SolidWorks Geometry By Workbench
Ashkan Javadzadegan
Rep Power: 17 |
Dear All,
I made a geometry by SolidWorks(IGES fromat) and imported it into Ansys Workbench. I am trying to open it by Workbench to change some of its boundaries; however, Workbench does not open it. Workbench opens without any geometry. Does anybody know what the problem is? Kind regards, AshtonJ |
March 12, 2012, 20:15 |
Erik
Rep Power: 23 |
did you right click where it is attached (tree on the left) and pick "generate"
March 12, 2012, 20:31 |
Ashkan Javadzadegan
Rep Power: 17 |
What I did; opened a "Transient Structural" then imported the geometry into "Geometry" part and then right clicked on it and chose the "Edit".
Is there anything more I need to do? Thank you AshtonJ |
March 12, 2012, 20:38 |
Erik
Rep Power: 23 |
Once Design Modeler is opened, If you look mon the tree where it says "XY plane" etc. There should be you geom etry that says Attach or something like that. click on it and hit generate. Then it will show your model.
March 12, 2012, 20:42 |
Ashkan Javadzadegan
Rep Power: 17 |
Thank you very much. It worked.
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
WorkBench Errors( Geometry not loading), Bad Autodyn cell template | tolu | ANSYS Meshing & Geometry | 4 | December 21, 2010 13:17 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
workbench geometry in ICEM | Ross | CFX | 6 | November 2, 2006 07:51 |
How to make surface (for opening) in WorkBench DM | Coriolius | CFX | 1 | November 12, 2004 17:23 |
