Alternative modeling of an perforated plate (not as a porous medium)
Old   March 1, 2012, 04:33
Default Alternative modeling of an perforated plate (not as a porous medium)
airflow is on a distinguished road
Is it possible to modelling a perforated plate as a “pressure drop” function of the velocity? I know I can realise that by a porous medium, but therefore I must generate a thin porous domain. Sometimes I got mesh-problems with that.
In CFX Pre is an Option for a “Domain Interface” called “pressure change”. Can I use that instead of a porous medium? Therefore I only need a baffle, which is easier to generate.
I have tried to model it by define the pressure drop as an expression:
-((velocity v)^2) * PressuredropCoefficient[kg m^-3]
But the simulation crashed after some iteration. (Velocity at monitor points rises up to supersonics)
If I use an averaged velocity, the simulation runs ok, but it is not physically correct….
-((areaAve(velocity v)@baffle_side1)^2) * PressuredropCoefficient[kg m^-3]
So anyone have an idea what I can do?
airflow is offline   Reply With Quote
Old   March 1, 2012, 18:07
Looks like some numerical instability which is fixed by averaging across an area. I assume the averaging approach is not correct for your application as the flow varies across the plate. In that case I would consider breaking the plate up into several small bits and averaging inside each bit. Then you should get some resolution of the flow variation but still get some numerical stability.
modeling perforated plate mokemex FLUENT 3 October 27, 2018 17:30
Modeling of perforated plate for 3 phase fluidized Sanyo FLUENT 5 March 27, 2015 12:01
Perforated Plate with Porous Media giogio FLUENT 4 July 8, 2008 16:07
Modeling thin perforated plates as porous media Mike FLUENT 0 August 21, 2007 05:16
turbulence at a porous jump (perforated plate) andrew FLUENT 1 May 8, 2004 10:51
