IAPWS water properties + orthotropic thermal conductivity |
February 29, 2012, 11:16 |
Rep Power: 16 |
I am using porous medium to model a part of my computational domain. In order to capture the net thermal conductivity of the porous medium, I use orthotropic thermal conductivity to define net thermal conductivity (consisting of thermal conductivity of water and solid, suitably combined to reflect net parallel and series conductivities) in x,y and z direction. Now I need water properties to be function of temperature and for that I define CEL expressions for different water properties (incluidng thermal conductivity) as a function of local temperature. I define a new material that is liquid and uses these CEL expressions for density, viscosity, thermal conductivity etc. Now I think I can use IAWPS properties of water instead of defining CEL expressions for water properties. Glen had suggested this once on this forum. But if I choose my material as water with IAWPS properties, I cannot modify the thermal conductivity to be net orthotropic one in x,y and z direction. I thought I could define a new material and somehow access IAWPS water properties to get the water conductivity part of net orthotropic conductivity. But that does not seem to be possible in CFX. Is there a way by which I can define a material that uses IAWPS properties for water such as density, Cp, viscosity etc and uses net orthotropic conductivities (consisting of IAWPS thermal conductivity of water and solid thermal conductivity) for the thermal conductivity in x,y,z direction? |
February 29, 2012, 18:26 |
Rep Power: 144 |
In V14 I think there is some new capabilities to allow you to model porous material temperatures and thermal conductivities. This means the fluid can still use normal material properties.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
