Geometry of Stage 37
Like Tree4Likes
Old   March 14, 2012, 07:32
dre
Martin
dre is on a distinguished road
No, I haven't. Unfortunately, I don't have turbogrid.
dre is offline   Reply With Quote
Old   March 14, 2012, 10:15
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
turbogrid geometry is attached at Post # 11 in this thread.
Far is offline   Reply With Quote
Old   March 14, 2012, 10:35
Oleg
olegmang is on a distinguished road
In fact, I have coordinates in more convenient format for you (see attached). I've already extracted them from turbogrids rotor for each section and put into separate .txt files that you can easily import to SolidWorks and then loft a surface.
olegmang is offline   Reply With Quote
Old   March 14, 2012, 11:49
Raja_Bhai
tauqirnawaz is on a distinguished road
Originally Posted by dre View Post
I just constructed rotor 37 again using solidWorks only. I assume, that the reason for the differences are the creation of the radii at the leading and trailing edge.
I imported all points into SolidWorks. Afterwards I created an arc at the tailing and leading edge with the last and first point of the manufacturing coordinates as maximum and minimum, respectively. Then, I use splines to connect both arcs using the rest of the imported points:
Acctually, the length of the rotor is given by the manufacturing coordinates. So there should be no variations.
There is an easier way to do this;
1. Copy the points of each profile in a text file and name it i.e. Profile1.txt
2. use Insert>Curve>Curve Through XYZ Points
3. Browse the profile text file and click OK
4> Use surface loft
tauqirnawaz is offline   Reply With Quote
Old   March 14, 2012, 12:19
Far
Sijal
This thread is becoming more and more informative, interesting and highly technical. This information, being discussed here, is very rare and mostly unknown except major companies.
Old   March 14, 2012, 12:35
dre
Martin
Thanks for your idea, tauqirnawaz. I'll try the turbogrid data and compare it to my rotor created with the manufacturing data.
Right now I just have the problem, that I can only use IGES to import the geometry to ICEM CFD (better data formats like *.sat and paraSolid are not working for me). Unfortunately, there are some surface errors and I have problems with the meshing.
At the moment, I created a quite coarse structured grid with about 350.000 cells for the rotor. I will start a first run tomorrow.
How about the tip clearance (0.1mm) and rotor hub radii (2.5mm)? Do you consider these?
Old   March 14, 2012, 13:11
Oleg
4> Use surface loft
Haven't I said the same in post before and even provided the .txt files?
tauqirnawaz likes this.
Old   March 14, 2012, 13:18
dre
Martin
Of course, you are right. I misunderstood you. I thought, I needed the CFD-Turbogrid software to assemble the rotor. I didn't think about using the data for SolidWorks :-) My bad!
Old   March 14, 2012, 13:24
Oleg
In report on Stage 37 there was tip clearance of 0.356mm and I'm not sure about rotor hub radii. And what about your geometry? Will you share it with everyone in general and with me specifically. I want to compare it with my and turbogrid geometries very much.
Old   March 14, 2012, 13:33
Far
Sijal
later it was modified to 0.4 instead of 0.356 mm.
Old   March 14, 2012, 13:44
dre
Martin
Sorry, I didn't mean the tip clearance, I ment the tip radius of the blade with 0.1mm.
I'll compare my geometry to the turboGrid data tomorrow and post my geometry in this thread. Hopefully, we can figure out the right rotor 37 geometry :-)
Old   March 15, 2012, 05:22
Oleg
I can't wait to see the results
Old   April 4, 2012, 07:18
Oleg
Unfortunately more then 2 weeks has passed and there is no results of geometry comparison from dre. I'm afraid that, at least I, wont ever know the truth
But the miracles do happen. Don't they?!
Old   April 5, 2012, 13:38
dre
Martin
Sorry for the late reply, but unfortunately I was involved in another project...
However, I have compared the rotor geometry from the turboGrid tutorial and the measurements from 1978. There are some differences regarding the blade angle (see picture 1). Another Problem of the measurement data is the leading and trailing edge, which doesn't look very smooth (see picture 2).
I think it should be possible to generate a new bladeGen file for TurboGrid with the measurement points. This way, we could still use Turbogrid for mesh generation. Furthermore, TurboGrid interpolates a different number of blade layers, so maybe the trailing and leading edge can be smoothened.
Otherwise, I have no idea what to do with the two geometries (or which geometry to choose). I think a simulation comparison would be good. Maybe the performance map for both geometries compared to the experimental results?
I have also attached the blade geometry from both for icem cfd.
Picture 1:
Picture 2:
Old   April 6, 2012, 05:36
Oleg
dre thank you for your persistence. Unfortunately we didn't get the final results. But i can say that i've built the geometry in a different way. So it would be very interesting to see the results of your geometry calculation comparison with the experiment.
Regards, Oleg
Old   April 6, 2012, 05:38
Oleg
dre thank you for your persistence. Unfortunately we didn't come to the final conclusion (what is the right geometry). But i can say that i've built the geometry in a different way. So it would be very interesting to see the results of your geometry calculation comparison with the experiment.
Regards, Oleg
Old   April 6, 2012, 15:35
dre
Martin
Does anyone have a clue about the second profile curve file in the TurboGrid rotor 37 dictionary? Is it the stator geometry, or maybe something else? I'm at home right now, so I cannot compare it to the measurement data.
Regarding my simulation results: I want to simulate this case with OpenFOAM. However, I think I will need another week or so until I can get some results. It would me great to compare these afterwards :-)
Regards
Old   May 12, 2013, 22:18
zhangjian
zjvskobe is on a distinguished road
The link is ok, but can't get the right file...
Originally Posted by olegmang View Post
Hi guys. After my bloody struggle with Stage 37 I want to share with you results that I've got and, maybe, discuss them (if someone obtained something else)
First of all is 3D geometry of Stage 37.
http://uploading.com/files/1be6418c/Geometry.zip/
Geometry.zip - 421.4 KB
<a href="http://uploading.com/files/1be6418c/Geometry.zip/">Geometry.zip - 421.4 KB</a>
I'm not sure what link should I post so I've put all of them.
Hope that this will be useful because when I started this project I haven't found 3D blades geometry. So, geometry of rotor and stator was created in Solid Works 2010 basing on report NASA TP-1337. I took all points from the report, created curve from them and lofted a surface on those curves. You can look for details in files.
Second is performance curve comparison. I've compared experimental curve with the calculated one and found that it had lower pressure ratios and MFRs. And, of course, I thought that I've done something wrong. But, after I found an article "CFD SIMULATION OF FOULING ON AXIAL COMPRESSOR STAGES" from ASME Turbo Expo and there they got similar results (i attached screenshot with comparison of experimental performance with the one from the article and my one). As you can see the article authors got almost the same results as I did.
What do you think about these results? Maybe someone got better coincidence with experiment?
Regards,
Oleg
zjvskobe is offline   Reply With Quote
Old   December 9, 2013, 07:09
Default 3d blade geometry
  #39
HUSSIEN SADEQ SULTAN
SAJADHUSSEEN is on a distinguished road
Hello, we have a research on film cooling in gas turbine blades. Our problem is the generation of blade geometry if you can help us we will be very thanks for you. my email is (sajadhusseen@gamil.com)
SAJADHUSSEEN is offline   Reply With Quote
Old   December 4, 2014, 23:44
Default Reg: Geometry of stage 37
  #40
Pauline
pauldarla89 is on a distinguished road
Hello olegmeng
I have seen that you shared your Geometry file through discussion forum and you are right, we couldn't find any data's in public.But after 2 years of uploading i can can't access your files. It say's "the file is removed". Can you please share it with me again? My email id is paul.totty89@gmail.com.
Thank you in advance
pauldarla89 is offline   Reply With Quote
Geometry of NASA stage 35 nana Main CFD Forum 13 June 6, 2024 08:17
Nasa stage 35' geometry huli2003 Main CFD Forum 12 February 27, 2021 06:48
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
Stage 37 Geometry A.S. Main CFD Forum 0 June 1, 2007 02:56
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
