how to write torque (of pump rotor) to file automaticly? (CFX)
Old   February 28, 2012, 12:55
Question how to write torque (of pump rotor) to file automaticly? (CFX)
Hai Yu
yuhai is on a distinguished road
hallo, dear friends,
I am trying to find a way to write out the value of torque on a rotor, for each time step (from the third rotation to end of simulation), to a .txt file. (it would be much better, if i can get a time-averaged value for it by the end.)
I hope that could be done in an automatic way, that means, it could be done with a command-line command, or just by settings in the .def file. Because I need to do hundreds of simulations, and I don't want to do this each time by hand.
Can you give me some ideas? must I use User-Fortran? or just some settings in CFX-PRE?
(I am using CFX, transient)
Thanks in advance!
yuhai is offline   Reply With Quote
Old   February 28, 2012, 18:22
The tutorials include an example of how to do something similar. Have a look at the immersed solid example.
Alternately you can write it to a monitor point and use cfx5mon (I think that's the right command, better check it) to extract it. Then a simple batch/script file can process it and produce whatever information you want.
ghorrocks is online now   Reply With Quote
Old   February 29, 2012, 11:18
Hai Yu
Thank you Glenn,
the command is cfx5mondata -res CFX_029.res -varrule "CATEGORY = USER POINT" -out aaa
cfx, files, torque
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
