February 13, 2012, 07:18 |
#21 |
Rep Power: 144 |
Why do you want a sub region?
February 13, 2012, 08:02 |
#22 |
Rep Power: 14 |
The CH 17 tutorial uses an impeller blade (a thin surface between the solid and blade) to create an interface for the impeller. IDK, I'm just trying to mimic the tutorial. Is there a way to do this with only using lids and an inlet/outlet boundary condition? I don't want permanent boundary condition values because I want the "fan" to do the work.
February 13, 2012, 17:33 |
#23 |
Rep Power: 144 |
Also do the flow in an axial rotor/stator simulation. That will show a different approach to rotating machinery modelling.
Don't forget that if you use a momentum source approach (ie do not model the fan but only its momentum added to the flow) you can define the source term to follow the fan performance curve. This means you are not using permanent values and the fan does the "work". |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 16:46 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
