January 27, 2012, 05:32 |
heat flux at fluid solid interface
Rep Power: 15 |
Hi
I am simulating a heat transfer problem where, one side of the solid domain has a wall heat flux in small patches(not all the wall on one side) and the other side of the solid domain has air flowing over it. How does cfx calculate the heat flux at the fluid solid interface? pl. do help asap Regards |
January 27, 2012, 07:30 |
Rep Power: 144 |
Yes, definitely. Look for the wall heat flux variable.
January 27, 2012, 09:14 |
Rep Power: 15 |
Hi ghorrocks
thanks. I am running cases with finer and finer meshes (for grid independent study), but I dont see any considerable change in wall heat flux( number of nodes have been increased from 7,14,28,56 (for 6mm air gap) and i want to know how does this wall heat flux(or local heat flux) and local delta Temperature vary. Is there a way to show these from results file in cfxpost? Regards |
January 27, 2012, 10:33 |
Rep Power: 15 |
Hi herewith i have attached the temperature contour. but the wall heat flux has almost the same value for all these cases. any suggestions pl.
January 27, 2012, 12:12 |
Edmund Singer P.E.
Rep Power: 21 |
Why do you think that the wall heat flux changes?
If you are running a ss analysis, with constant heat coming in one side of the solid, air flow on another side and I assume adiabatic on the other sides, the heat flux will remain constant (qin=qout). Mesh density will not alter this, energy should still balance out if convergence is achieved. |
January 30, 2012, 11:55 |
Rep Power: 15 |
Thank u singer
January 30, 2012, 12:05 |
Rep Power: 15 |
Hello
I dont find any variation with respect to the mesh refinement. Temperature is varying up to 2deg(at hot spots) with increasing the nodes 4 times the earlier coarser grid(step by step) Is there a problem? I use K epsilon model(scalable wall function) pl. do suggest |
Help needed in meshing for Solid to Fluid Heat Transfer | niazaliahmed | FLUENT | 2 | February 22, 2020 16:47 |
Solid to Fluid Heat Transfer Modelling Problem | bortonj88 | Main CFD Forum | 3 | November 14, 2011 15:21 |
Fluid - Solid Domain Interface | Daniel | CFX | 6 | February 15, 2009 19:09 |
wall heat flux between two fluid zone!!! | Asghari | FLUENT | 2 | August 25, 2006 11:11 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
