Force calculation help
Old   January 25, 2012, 09:38
Default Force calculation help
Tom Walker
tomwalker is on a distinguished road
I have set up an SST flow to simulate the air flow around an underground train. With these settings I am trying to calculate the drag coefficient of the train but when I do an expression to calculate the force on the train then it keeps giving me a value of zero. The train is only moving at 15 m/s so i know the force will be low but zero seems a little extreme.
Is there a really obvious reason why it is doing this?
All help is highly appreciated
Thanks
Tom
tomwalker is offline   Reply With Quote
Old   January 25, 2012, 10:27
Lance
Lance is on a distinguished road
Could you post your expression for the drag coeff?
Lance is offline   Reply With Quote
Old   January 25, 2012, 10:30
Tom Walker
i was going to work out the drag coefficient in excel later i just needed ansys to measure the drag force so that I can incorporate it into my equation
Thanks
Old   January 25, 2012, 10:34
Lance
Originally Posted by tomwalker View Post
... but when I do an expression to calculate the force...
so how does this expression look like? What do you want to export to Excel (and why?).
Old   January 25, 2012, 10:37
Tom Walker
The only value i need out of ansys is the value for the force acting on the body in the same direction as the air flow (i.e. the drag force) using this value I can then use:
Cd = (2Fd)/(density*velocity*velocity*area)
Old   January 25, 2012, 10:40
Lance
Yes, that's the expression for the drag coeff, but I asked about your expression for the force (that apparently becomes zero...)
Is is something like:
force_x()@some_area?
Or its equivalent
areaInt_X(Pressure)@some_area+areaInt(Wall Shear X)@some_area
Old   January 25, 2012, 10:42
Tom Walker
oh right sorry, miscommunication there
Yes that is what my equation looks like using x because that is the direction of flow and the area is front (because that is the domain that is on the front of my train)
Thanks
Old   January 25, 2012, 10:56
Lance
Thanks
Well, it shouldnt be zero (as you pointed out ). Is it the same for other surfaces? Is the pressure integral also zero?
Old   January 25, 2012, 10:57
Tom Walker
I haven't checked the pressure integrals but looking at the force on the surface of the whole body it has given me a reasonable looking results
Thanks for your help
Tom Walker
Old   February 14, 2012, 10:07
Default train moving in tunnel help
sheikh nasir is on a distinguished road
hello
i am working on train moving in tunnel. i am getting floating error:invalid number. can any one help me. my email is sheikhnasir39@gmail.com
plz help me
thanks
sheikh nasir is offline   Reply With Quote
cfx, drag coefficient, force
Pressure force calculation in incompressible solvers philippose OpenFOAM Running, Solving & CFD 10 December 7, 2019 05:51
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Viscous Force Calculation cwang5 OpenFOAM Programming & Development 1 May 4, 2010 05:59
Comet - force calculation Tony Campbell Siemens 10 December 7, 2004 15:53
Warning 097- AB Siemens 6 November 15, 2004 05:41
