A rotating blunt body within a "box" of air at an angle? |
January 11, 2012, 09:29 |
calvin Lin
Rep Power: 15 |
I am trying to do flow simulation for a shuttlecock that is spinning and flying at an angle to the flow field.
I have set the domain on cfx-pre as rotating. The shuttlecock is a non-slip wall as taught by the tutorial. I also set the shuttlecock as rotating under boundary. However, I don't understand how to set the others, like inlet, outlet and other sides of the box of air. 1. Do I set the inlet and outlet as rotating or stationary? 2. Since the outside wall is set as a free slip wall, it really does not matter if it rotates or stationary right? 3. Short of creating a geometry file for each angle of attack, can I just modify the inlet condition or? How should I go about testing different angle of attack? 4. If I change the flight angle through the way the shuttlecock is positioned in the box, then when I set the rotation of the wall, will it mean that my shuttlecock will now cocksrew instead of really spinning? |
January 11, 2012, 20:25 |
calvin Lin
Rep Power: 15 |
I tried setting the inlet velocity as cart. and giving it velocity in 2 directions to simulate airflow with angle of attack. It seems that I am having issue with the flow not flowing out...causing error. How do I fix this?
Rotating Disc in a Volume of Air | alcesalces | FLOW-3D | 5 | August 28, 2009 18:04 |
Solver for a Rotatinng Disc in a Volume of Air | alcesalces | Main CFD Forum | 0 | August 19, 2009 15:33 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 08:25 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 08:04 |
