January 10, 2012, 11:10 |
CFXPOST V13 Mirror Transform without Copy
Edmund Singer P.E.
Rep Power: 21 |
Anyone know how to do this? I want to mirror a contour, but the mirror transform retains the original contour.
I cant rotate the contour (which doesnt retain the original copy) becuase it is a 3D object with different contours on the front and back side. Rotation just shows the other side of the contour, which is not what I intend. |
January 10, 2012, 11:15 |
Edmund Singer P.E.
Rep Power: 21 |
Sorry to reply to my own post, but would like to remove one other method someone might suggest. I tried rotating 180 degrees with face culling, which almost works, but shows unwanted interior geometry, so that can't be used.
January 10, 2012, 16:38 |
Rep Power: 21 |
A Clip Plane could hide the original copy, but it would hide everything else too. Do you need to retain some bits of the original geometry?
January 10, 2012, 16:41 |
Edmund Singer P.E.
Rep Power: 21 |
The reflection plane cuts through the center of the body, so a clip plane doesn't work. But that does give me an idea, I could mirror and translate a large distance and zoom in to exclude the original body.
I will give that a try, thanks! |
January 10, 2012, 18:27 |
Edmund Singer P.E.
Rep Power: 21 |
Just as an FYI, the translate and mirror doesn't work. Any other ideas appreciated.
January 10, 2012, 20:41 |
Rep Power: 144 |
This is pretty horrible but you could export the contour line as XY points then do the mirror yourself and then re-enter it into CFD-Post as a points. If nothing else works this might do it.
January 11, 2012, 09:59 |
Edmund Singer P.E.
Rep Power: 21 |
Horrible is the right word for that!
I dont think that will be practical in my case. I am generating eyecandy movies for upper-ups and wanted the front and back side of the item pointing in the same direction (I am using a 2 view window to display both at same time), and thought someone might have something quick and clever that would work. I will probably end up generating it without the mirror. |
January 11, 2012, 12:47 |
Edmund Singer P.E.
Rep Power: 21 |
As an FYI to the forum. Got word back from CFX and this behavior is a bug. They are hoping to have it fixed in V14.5
Got a copy of AGARD Report AR-275? | screech1987 | Main CFD Forum | 2 | July 20, 2015 18:33 |
Can I make a copy of a patch mesh and move it? | bigphil | OpenFOAM Programming & Development | 0 | October 13, 2010 11:29 |
Is it OK to copy Wikipedia article to CFD-wiki? | CFDer | CFD-Wiki | 4 | December 11, 2009 07:16 |
copy mesh with icemcfd for structured grids | michael | Main CFD Forum | 3 | July 27, 2006 09:40 |
looking for a free copy | zakaria | Siemens | 3 | November 9, 2004 11:49 |
