Solution on hexa mesh vs solution on tetra mesh |
December 8, 2011, 18:55 |
Rep Power: 16 |
I have a block structured hexa mesh (made in ICEM CFD) for my geometry and a converged solution for fluid flow and conjugate heat transfer on this mesh (solved in CFX). I have not used tetra mesh with prism layers before for fluid flow. I now want mesh the same geometry with the automated tetra + prism layer mesh in ICEM CFD and solve the same problem as above for this mesh and then compare the results with those on the block structured hexa mesh. How should I ensure that any difference in results that I finally get is only due to change in nature of mesh from hexa to tetra and not other factors like mesh density etc.? Thanks for your inputs |
December 9, 2011, 05:22 |
Rep Power: 144 |
Do a mesh sensitivity study of both meshing options separately. You can only compare fully mesh independent meshes of each type to get a meaningful result.
December 10, 2011, 10:35 |
Rep Power: 16 |
Thanks Glen for your reply. Yes, that makes sense. I will do grid independence studies on both types pf meshes as per your suggestion before comparing the results.
Best regards. |
cfx, hexa mesh, tetra mesh |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 08:51 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
dynamic mesh on a hexa grid | Manoj Kumar | FLUENT | 0 | August 21, 2007 08:41 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
