Porous domain set-up from single pressure loss value |
December 8, 2011, 10:53 |
Stuart
Rep Power: 26 |
For porous domain modelling I usually have a table and graph of volumetric flow rate (Q) vs. pressure loss (dp). From the quadratic equation of the graphed data I can get the 2 coefficients for CFX. However, for a current task I only have a single value of dp at a single Q which was experimentally recorded. How can I set up a CFX porous domain with this limited amount of data? I have the actual geometry of the porous domain which has a rectangular cross-section and a thickness. Experimental work will definitely not be done to get more data and to be able to make a graph of Q vs. dp. The aim of the simulation is to visualise the flowfield inside the device which also includes the porous domain. Thanks |
December 8, 2011, 17:36 |
Rep Power: 144 |
Have a look at the porous flow equations, and maybe some academic papers on porous flow. You will probably be able to evaluate all the coefficients even though you only have one point as the porous flow curve should be known.
Interface between fluid domain and porous domain | windhair | CFX | 6 | May 10, 2018 15:26 |
How to choose or find Permeability for a Porous screen model using darcy's law.... | arunraj | CFX | 4 | September 27, 2011 01:20 |
Pressure Loss dependet on Flow Direction | MichaelN | CFX | 2 | June 5, 2011 12:22 |
Momentum source / porous loss | ijk | CFX | 5 | May 20, 2011 11:30 |
Porous region set | braket | FLUENT | 4 | November 18, 2010 03:09 |
