How to do analysis at backward facing step
Old   December 8, 2011, 10:51
Default How to do analysis at backward facing step
warlocklw is on a distinguished road
Image above is Backward Facing Step. The upper side is inlet, the lower side is outlet. I need to do analysis at the step height area. Is there any analysis I can perform? I was told to do analysis of wall shear, mass flow, shear stress, shear strain and velocity. I already done velocity by using graph a line, contour and streamline. Please enlight me for the other analysis. Thanks in advanced.
warlocklw is offline   Reply With Quote
Old   December 8, 2011, 17:34
There are millions of academic paper analysing this flow. have a look at some and see what they use as their key flow parameters.
Old   December 11, 2011, 05:12
Thanks. I get some idea now. However, I have difficulties at finding the vortex at the step area.
From picture above, right side is inlet, left side is outlet. I do streamline using cfx, and it's 3D streamline start from inlet. The variable is velocity. How do I make cfx to 'sketch' the vortex at step area? It's 500 Reynolds Number by the way, and fluid self-circulation should exist at step height. Is there any method for me to view the vortex/self-circulation at step? Thanks in advanced. By the way I am using ANSYS 11.0.
Old   December 11, 2011, 11:02
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
release pathlines from adjacent location
another method is to use the tecplot or feildview, you will get very nice pictures
Far is offline   Reply With Quote
Old   December 11, 2011, 19:04
You do not need tecplot or fieldview for this, CFD-Post will do it just fine.
You need to think laterally a bit to show some of these features.
If you want the separation length then look at the u velocity on the bottom wall. The point which has zero u velocity is the separation reattachment point.
If you want a picture which shows the recirculation then simply put some streamline seed points in the separation region. You can do this either manually, or using the domain with a reduction factor. Adjust the reduction factor to give you a few points in the recirculation region but not too many points.
Far: Your image with a release point will not work. streamlines started from your line will simply jump over the separation region. You need to seed streamlines inside the separation region.
Old   December 21, 2011, 07:50
Smile
Reduction factor 1.0 did shown recirculation zone at step height. Thanks a lot.
Backward facing step sega OpenFOAM Running, Solving & CFD 8 June 2, 2011 01:07
Fluent and backwards facing step Ben Sellars Main CFD Forum 2 February 3, 2007 13:36
Reg: Supersonic flow past backward facing step kiran Main CFD Forum 0 September 30, 2006 06:07
Backward Facing Step Jimmy Main CFD Forum 3 July 25, 2004 23:37
turbulent flow over a backward facing step Kirill Main CFD Forum 4 November 5, 2002 10:04
