Moving coordinate frame
Old   November 23, 2011, 12:51
Default Moving coordinate frame
Roland Rakos
Roland R is on a distinguished road
I would like to rotate my subdomain with deforming mesh. This is OK. But this domain moves in a straight line too. Rotation of the body is based on the original X-Y-Z coordinate frame but of course it should move with the body together.
How can I define moving coord frame?
Regards
Roland
Roland R is offline   Reply With Quote
Old   November 23, 2011, 15:16
Edmund Singer P.E.
singer1812 is on a distinguished road
This is very easy to do, particularly if you are deforming the whole subdomain (then remeshing isn't necessary). If you use rotation and translation matricies to determine your movement you can combine the translation and rotation into one equation, and it can be as complicated as you wish it to be. If you remesh, you will need to add in a de-rotation (of the rotation at the remesh time) and a de-translation (at the time of the remesh time) matricies prior to the actual rotation and translation.
If you give more details on how you are trying to move your mesh, perhaps I can be more specific in an example.
singer1812 is offline   Reply With Quote
Old   November 28, 2011, 05:42
Roland Rakos
Hello Singer,
thanks for your answer, but could you give me more detailed explanation? To tell the truth, I don't understand quite...
My problem:
I would like to simulate a simple 3D aircraft during a genaral figure looping. In addition strong wind attacks the aircraft body therefore the original circle figure will deform. I would like to analyse this deformed looping with combination of translation and rotation.
Regards;
Roland
Old   November 28, 2011, 10:59
Edmund Singer P.E.
By figure looping do you mean something like this?
And if so, couldnt the translation be taken up via the inlet velocity so that you would only be dealing with pure rotation of the body?
CFD Post- coordinate frame issue GSbert ANSYS 1 June 15, 2012 02:26
Moving refence frame yagizb FLUENT 0 March 19, 2011 04:14
does sb can tell me what is the differences between moving mesh and moving frame? caohan FLUENT 0 June 2, 2010 06:15
Help for Moving Reference Frame. aiqch Main CFD Forum 0 April 3, 2009 01:23
Moving reference frame CFD_boy FLUENT 6 April 20, 2006 12:39
