November 20, 2011, 01:55 |
CFX 13 error on windows 7, 64 bit
kits youhara
Rep Power: 16 |
Hello to everybody after a while,
I am trying to install ANSYS CFX 13.0 on my windows 7, x64 laptop but I have met the following problems: When uncompressing the files and then try to make the installation, I get a message that says that the program will be terminated. When going directly from the zip file, the installation is normal, but when trying to launch CFx I get a message that says something about fatal error, and unicode conversion malfunction. I have deactivated my UAC and installed CFx on both directories, program files and program files(x86) Has anybody met such difficulty or has any idea about what's going wrong? ps. I downloaded my software from ansys customer portal, I would really appreciate any help. Kind regards |
November 20, 2011, 06:09 |
Rep Power: 144 |
Did you check the MD5 of your download? The portal has the MD5 sums for all downloads so you can check you downloaded it correctly.
I have had dud installations previously from failed downloads which looked OK. The only way to be sure is to check the MD5. |
November 20, 2011, 09:46 |
kits youhara
Rep Power: 16 |
To be honest I do not really know what MD5 is. Could you quite enlighten me? Where can I check this from on the download site?
November 20, 2011, 17:52 |
Rep Power: 144 |
If you don't know then google it.
MD5 is built in for Linux I think. Here is a windows/DOS implementation of it: http://www.fourmilab.ch/md5/ |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
Ansys CFX 11 on Windows7 ( 64 bit) | mohammad | Hardware | 1 | March 10, 2011 09:03 |
CFX local parallel on windows XP | frank | CFX | 12 | April 24, 2008 08:26 |
windows vista anda cfx 11.0 | javi | CFX | 4 | November 6, 2007 21:36 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
