November 17, 2011, 18:05 |
Mesh Displacement Residual
Lingdeer
Rep Power: 15 |
I am running 2way FSI coupling ANSYS and CFX.
Both for fluid and solid solver I saw them converging well. However, the residual of the mesh displacement remains high: 10e-1 I tried to increase the no. of max coeff loop in equation class setting under solver control from 10 to 30, because I am thinking may there isnt sufficient loops for it to converge. However I don't know how to monitor it, to see if this is improving by allowing it to run more no. of loops. Anyone has any idea? Thanks! |
November 17, 2011, 18:23 |
Rep Power: 21 |
The out file shows all the loops and the residuals for the mesh displacement equation. Are you using double precision? If not, turn that on. Note that as long as your mesh doesn't fold then these residuals do not change the accuracy of your solution. Higher residuals may cause the mesh to fold sooner if you are deforming it a long way though.
November 17, 2011, 18:54 |
Lingdeer
Rep Power: 15 |
I see. Thank you stumpy!
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 05:13 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 14:38 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 08:11 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 21:21 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
