Implement swirl as "internal" BC with calculated u_axial |
October 27, 2011, 05:18 |
sirLentschi
Rep Power: 16 |
Hello everyone,
as you can see in the attched pdf-file, I want to calculate the case as follows: A diffuser is determined in a water volume, the "global BCs" are the Velocity u=2m/s (Inlet) and p=0bar (Outlet). Now I want to implement a "swirl" as additional interior BC at an interface with the velocities (in cylindric coordinates) v_radial=1m/s and v_theta=0.8m/s, though v_axial should be the calculated u at this mentonoid interface!! In fluent and OF it is possible to arranged that. But is this possible in CFX 13 too?And how can I implement it?? Thanks in advance. Regards Last edited by lentschi; October 27, 2011 at 05:47. |
October 27, 2011, 05:49 |
sirLentschi
Rep Power: 16 |
Sorry, I forget the pdf....
October 27, 2011, 07:13 |
Rep Power: 144 |
Sounds like this should just be a momentum source term. Look it up in the documentation.
October 28, 2011, 08:16 |
sirLentschi
Rep Power: 16 |
thank you for your reply but there establish some problems with the momentum sources: 1) this is only for subdomains, not to use for Interfaces/BC (maybe I have overlook/missunderstood something) 2) I need velocities, not momentums Regards |
October 28, 2011, 16:49 |
Rep Power: 144 |
To fix 1 you just make the entire domain a subdomain. But the second part of your question is the crux of the problem, I cannot think of a way to make it act only at the interface and in the correct direction.
Question 2 is fine, a momentum source can specify velocities. The "momentum" refers to what equation it applies to, not what is applied. |
November 2, 2011, 03:53 |
sirLentschi
Rep Power: 16 |
OK,thank you for your answer!
Regards |
November 2, 2011, 05:58 |
D
Rep Power: 16 |
Are you trying to simulate something which actually physically exists ? if, yes, what is the actual arrangement there ?
Howe to get swirl velocity component in 2D axisymtric swirl modeling | Perra | Fluent UDF and Scheme Programming | 2 | March 6, 2018 03:14 |
Swirl in Pressure Swirl Atomizer | varunrajendra | FLUENT | 0 | August 19, 2009 13:09 |
Quantifying Swirl | Ianto | Main CFD Forum | 0 | April 27, 2009 11:54 |
2d axisymmetric with swirl | heather | OpenFOAM Running, Solving & CFD | 5 | July 28, 2005 18:20 |
Swirl in backflow on pressure outlets | Jonas Larsson | FLUENT | 17 | February 3, 2000 03:14 |
