October 19, 2011, 04:50 |
Problem with Additional Variables
Frank Weise
Rep Power: 17 |
I try to simulate a diffusion process through a thin sheet in a closed chamber. The aim is the Oxygen concentration depending on time in the chamber. For this transient simulation I used a Additional Variables type Volumetic and as Units [mol/m^3]. I've select Diffusive Transport Equation at both Domains and a different Kinematic Diffusivity. My problem is that the time to the equilibrium state depends on the density of Fluid in the chamber. As far as I know is, that depends only on the diffusion constant. What did I do wrong? Thank you in advance! |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 05:26 |
Source terms for additional variable transport eqn | Nandini Rohilla | CFX | 0 | February 6, 2004 14:38 |
Q on additional variables in CFX5 | bobbob | CFX | 0 | April 29, 2003 10:25 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 23:00 |
