Problematic interface in a rotatory-stationary domains |
Jordi Bartrons
Rep Power: 15 ![]() |
I have a stationary domain which is a pipe and a nozzle inside and a rotatory domain which is a propeller inside the nozzle. I setup all the components in a turbomode on CFX Pre, but I'm confusing in order to check the regions. And when solution starts, is post: | ERROR #555000013 has occurred in subroutine CHECK_FACE_ETA. | | Message: | | | | Coordinate transformation of Side 1 of interface | | Internal Interface 1 | | failed because some faces have an eta extent smaller than the | | allowed value. This can happen if the interface contains some | | faces that are parallel to the rotation axis and others that | | are perpendicular. The transformation algorithm does not permit | | both of these face types to coexist in the same interface. The | | minimum value of the face eta range is 0.000E+00. | | Please check and modify the topology or set the expert parameter | | 'ggi minimum face delta eta' to a value less than the reported | | minimum face eta range. | +----------------------------------------- Does anyone jnow about this? Thank you very much |
#2 | |
NING
Rep Power: 0 ![]() |
cfx, domain interface, interface, rotating |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
2 Domains share their walls...any interface ? | KK | CFX | 2 | February 7, 2008 17:34 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
