Poor convergence with high streamwise loss multipler
Old   September 21, 2011, 17:38
Default Poor convergence with high streamwise loss multipler
mullenc525 is on a distinguished road
I am doing flow distribution analysis where I am using a porous media to simulate many small channels within a heat exchanger. I want to force the flow to be parallel within the porous media, which necessitates a high streamwise coefficient multiplier. The difficulty I am having is when I make the multiplier much bigger than 10, the solution convergence becomes highly oscillatory and I can't get good convergence.
Any ideas?
mullenc525 is offline   Reply With Quote
Old   September 21, 2011, 20:20
I suspect the tips here will be relevant:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
ghorrocks is online now   Reply With Quote
Old   September 23, 2011, 17:54
David VanBronkhorst
dvanb is on a distinguished road
Apologies if I am not remembering this correctly, it's been a couple years since I did this kind of simulation, but:
you are saying you need a large stream-wise loss coefficient. I would think that in fact the directions _normal_ to the stream should have the very high loss coefficients to suppress crossflow. Your stream-wise coefficient should be whatever you need to simulate the expected pressure drop through the HEX for a given flow rate.
dvanb is offline   Reply With Quote
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 13:29
Temperature loss in compressible solvers in high speed flows vkrastev OpenFOAM Running, Solving & CFD 1 June 16, 2018 08:10
loss calculation in simulation of turbomachines playmaster Main CFD Forum 0 August 21, 2010 06:59
Directional loss model Cenci CFX 6 December 20, 2005 15:33
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
