Cavitation problem...
Old   September 15, 2011, 09:59
Default Cavitation problem...
Roland Rakos
Roland R is on a distinguished road
I would like to simulate the next phenomenon:
There is a small cylinder which is loaded with water fully. (Cylinder is fully closed.) Volume of the cylinder starts to increase slowly until the start of the cavitation process. Finally the volume decreases back to the original value, the cavitation bubbles disappier, the water vapour turns into water and water phase will be in the full field again.
In the simulation this process operates until the beginning of cavitation, water wapour develops in the field, but this phase does not turn into water after decreasing of the volume.
Are there some ideas to solve this problem?
Thanks in advance;
Roland
Roland R is offline   Reply With Quote
Old   September 15, 2011, 11:12
Edmund Singer P.E.
singer1812 is on a distinguished road
Make sure you use slightly compressible water.
singer1812 is offline   Reply With Quote
Old   September 15, 2011, 11:22
Roland Rakos
The water is compressible in the simulation
Old   September 15, 2011, 11:40
Edmund Singer P.E.
My apologies, I didnt read your thread thoroughly enough. I thought you were asking about general modeling, didnt see that you were asking about condensation of the vapour phase.
Are you using the your cavitation model or what? Did you verify that the pressure in the vapour regions is heading above the vapour pressure?
Are you sure it is not turning into water? Are you monitoring the total amount of vapour in the volume as a function of time? If it is decreasing, perhaps you just havent run the simulation long enough.
convergence problem with FLUENT cavitation model Belete Kiflie FLUENT 3 February 20, 2006 11:16
cavitation problem dhiman FLUENT 0 February 2, 2006 11:58
Cavitation Simulation by CFD Liu, L. CFX 2 November 29, 2000 14:50
Cavitation Simulation by CFD Liu, L. Main CFD Forum 7 November 1, 2000 22:26
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
