Modeling of water infiltration into a tank containing a permeable soil
Old   September 13, 2011, 05:32
Default Modeling of water infiltration into a tank containing a permeable soil
idir
idir is on a distinguished road
Hello all
I need to model the infiltration of water into a tank containing a permeable soil during a time t.
For this I referred to tutorials (Chapter*9:*Free Surface Flow Over a Bump) and (Chapter*12:*Flow in a Catalytic Converter) to do the modeling (see attachment 1 to 10 ):
*Analysis type : Transient.
*2 domains:
1-->Water_and_Airas in tuto9:free surface flow)
2-->SoilPorous domain as in tuto 12)
but the results obtained are not normal (incorect) (see attachment 11to 14) .
Please send your views and advice about the boundary conditions and Domains so on.
Thank you in advance.
idir is offline   Reply With Quote
Old   September 13, 2011, 05:34
idir
following of the attachment
Old   September 13, 2011, 05:37
idir
and the results of this simulation
Old   September 13, 2011, 09:15
What is incorrect about the results?
Old   September 13, 2011, 10:14
idir
Hi
The problemes are:
1- the water level above land does not decrease over time
2- and when I change the properties of the soil making it more permeable (volume porosity and permeability of 0.9 to 0.2) I find very different results (see photos1 to 5) and her also the water level does not decrease
Old   September 13, 2011, 20:22
1 - How are your imbalances? If the Volume fraction variable has a small imbalance then it is being conserved and the top surface should be moving properly. If not then you need to converge tighter.
2 - You have a fluid region above an air region which you suddenly release. In the absence of the porous region this would result in a chaotic mixing and splashing behaviour - this looks very similar to what you are getting. Are you sure your porousity is high enough to get the effects you are looking for?
Also as you do not have a sharply defined free surface, have you turned on the free surface model? Are your time steps fine enough to resolve the motion? Do you have the correct volume fraction differencing scheme (compressive is the one you want here)?
Old   September 14, 2011, 07:03
idir
Thank you for your answer
I do not understand what you mean by "the volume fraction imbalance variable"
But In this simulation i set the initialization of:
Water domain: Water VolumFraction = 1.0 /AirVolumFraction = 0.0
and
SoilPorous domain: Water VFraction = 0.0 / AirVFraction= 1.0
and I do not know if it's good or not?
about Free Surace model it was turned off, and now I turned it on and I start the new calculation, and I will give you the results tonight.
Thank you in advance ghorrocks.
Old   September 16, 2011, 07:07
idir
Now it's ok it works, you have just to turn on free surface option in Solver
thank you
Old   September 16, 2011, 07:40
Check out the end of the output file. It lists the variable imbalances and will have one for volume fraction. Also the solver manager will have a graph for imbalances and one of the lines will be volume fraction. You can also set convergence criterion on imbalances.
If that is the initial condition you want then it sounds good to me.
For a free surface problem that sounds pretty obvious to me.
Filling Tank with Water leff CFX 7 August 21, 2017 08:47
Simple Water Tank Transient 88phil88 CFX 5 March 17, 2014 04:48
Water Evaporation and condensation modeling Linjie FLUENT 3 February 6, 2012 14:08
modeling spilling of water from a tank jemteo CFX 6 June 25, 2006 20:33
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
