Rotating A turbine Blade
Like Tree1Likes
Old   September 13, 2011, 09:10
It should rotate if you set it up correctly.
And why did you use the immersed solid approach? This case is clearly an application for rotating frames of reference - as I said in a previous post.
Old   September 13, 2011, 15:29
charlestchan is on a distinguished road
I don't know why i still get error in the solution. I set domain 1 as fluid. Domain 2 as solid domain. Then i set boundary for fluid, the inlet and outlet as usual. Then i set interface type, fluid solid. And i make the analysis to transient. Could it be that i was wrong at setting the interface ?
charlestchan is offline   Reply With Quote
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
ROTATING TURBINE BLADE SIMULATION Anant FLUENT 2 March 31, 2011 11:57
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 18:06
Flow study through Turbine Blade passage Subrata FLUENT 1 May 4, 2007 12:28
