Changing Workbench Output Parameters - Update without re-solving? |
Max
Rep Power: 15 ![]() |
i've made some parameter variations on several workbench projects. I exported each design point, so the result files are still available. Now, I added some more output parameters. Is there a way to update my output parameters without recalculating all my CFX results? My input is exactly the same, so another solver run is superficial in my case. Thanks in advance! Max |
Rep Power: 18 ![]() |
Not as far as I am aware, the simulations are re-run after adding a new output parameter.
![]() Have you found otherwise? |
Max
No, I have not.
Matthias Voß
Rep Power: 20 ![]() |
you can try to push it by journaling the workbench project ... but this is quite time consuming (at least for me when debugging everything)
neewbie |
Refresh vs Update - What's the Difference? | CeceMarie | ANSYS | 0 | June 28, 2011 14:32 |
Ansys Workbench : Unable to update 3D Model | kh_thakor | ANSYS | 0 | January 22, 2011 05:34 |
Changing CFX.def in WorkBench Parametric analysis | sodjaj | ANSYS | 1 | August 23, 2010 11:04 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 13:30 |
Changing DILUPBiCG output when solving equation | nico765 | OpenFOAM Running, Solving & CFD | 8 | September 23, 2009 10:01 |
